can someone provide me a link to this exact page
It is old doc, not sure it will workā¦
https://github.com/emlid/reach-docs/blob/old-docs/docs/software-development.md
Thank you, Your link showed me where to find several helpful docs.
With my reach unit plugged in and partially booted, my unit is āHanging upā at a blinking āYellow?ā light.
when I ifconfig does NOT show usb0 in the list, consequentially āsudo ifconfig usb0 192.168.2.2ā yields the error āno such deviceā
any advice?
Iām working this error in another thread, I got here thinking a re flash would fix this, but I canāt seem to re flash if my reach unit wonāt connect
Did you get it working?
I have the same problem - yellow led is blinking. It worked before well with wifi. Then I tried to connect via USB. And not I cannot get the hotspot working (went out of the reach of any possible wifi).
@ago, I did. Its so long ago Iām having trouble bringing myself up to speed. Reflash was definitely my solution. I was using a modified wire to connect my Reach unit to a 3DR Radio, when I tried hooking to Navio2 with the same modified wire no connection. I switched back to the factory wire and the connection worked. Hope this helps.
Thanks for the reply! I am using factory wires.
I removed all the wifis from ReachView and rebooted the RTK module. After that it blinks yellow. And when connecting to the computer via USB, I get (dmesg):
[ 1330.894983] usb 2-1: new high-speed USB device number 15 using xhci_hcd
[ 1331.092302] usb 2-1: New USB device found, idVendor=8086, idProduct=e005
[ 1331.092311] usb 2-1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 1331.092315] usb 2-1: Product: MERRIFIELD
[ 1331.092320] usb 2-1: Manufacturer: INTEL
[ 1331.092323] usb 2-1: SerialNumber: 8EFB41A520794CD7002CE966F1ABEFF2
[ 1334.615380] usb 2-1: can't set config #1, error -71
[ 1334.615602] usb 2-1: USB disconnect, device number 15
The real question isā¦ is reach receive ntrip correction over usb/Ethernet link or via the serial com link. Is reach see the internet? And how to configure that link on navioā¦
I use a cable connexion to provide Ethernet to navio on raspberry pi3. How to remove wifi and access to ntrip caster without Mission Planner?
Hy all
I change the modem/router and now Iām not able to reach the wifi (5ghz) with my reach
m able to use the wifi of my phone cell so maybe the frequence of wifi signal isnāt correct ā
thx
francesco
