Shorting C1 Ground and timemark pins using led light
Hi!
Thanks for pointing out the 3.3V maximum voltage! That save me from frying my M2.
If I want to see how the time mark works I can just follow the general illustration I made below, make sure satellites are properly communicating with the M2 and I should see the dip in signal in reachview, right?
As you pointed out maximum of 3.3v, what could be the least voltage that will trigger the time mark?
Thanks.
