RTKPOST Version QT 2.4.3 Emlid b33 does not process the combination L1 + L5.
Any idea what it might be?
What error do you get?
it crashes and an APPCRASH error appears
Hi Mauricio,
Could you clarify why you need the L1 + L5 solution?
For Reach RS2 devices, please use the L1 + L2 option.
for tests
Hi Mauricio,
We’ll check what’s wrong here.
Hi Mauricio,
As I said earlier, Reach RS2 devices provide data for L1 + L2 PPK only. That’s why we’ll likely remove the L1 + L5 processing option from the app in future versions.
If you need to process L1 + L5 logs from 3rd-party devices, I’d recommend using other RTKLIB versions.
