As an happy Reach M+ user, I plan to upgrade my base setup by buying a Reach RS+ and keep using the M+ as a rover.
Does any body have an idea of the typical convergence time with this base/rover RTK setup, assuming that the RTCM3 is correctly transmitted? I can’t find any info in the specs.
I ask this question since I know that RTK systems usually have long convergence time (sometime greater than 15minutes) when the correction is not received from a local base.
I don’t have an RS2 yet, but comparable to Topcon Hiper V’s I can setup an RS+ base and rover and while waiting for it to fix, setup the Hiper V base/rover and be fixed 5 minutes before the RS+ ever indicate a fix.
