Hi all, purchased an RS3, to use as base. Using the caster, can get Novatel receiver working fine on some machines, can’t get Topcon AGI-4 to connect to base. All using NTRIP, sims are fine. Any help much appreciated.
Hi @kreg
Welcome to the Community Forum!
I’d like to check this for you. For this:
Can you tell me more about your setup with Topcon AGI-4 and its configuration setting with NTRIP? Can you share a screenshot of the settings?
Do you see the base (RS3) and rover (Topcon) online in Emlid Caster?
Hi, thanks for the response. Can get the AGI4 receiving from base, just failing to achieve an RTK fix. AGI4 is connected to a Topcon X30. Can’t seem to achieve anymore than the base saying “Single” not “Fix”, not sure if this is the problem. Works fine through Novatel receiver on other machines
When using Emlid Caster, it acts as a bridge to transmit corrections between your receivers over the Internet. point, and have a stable internet connection. From the Caster side, your receivers must support the NTRIP protocol, be connected to the same mount point, and have a stable internet connection.
To help with your issue, I’d like to know what you are using as your base and rover. While I can explain and help with setting up and configuring your Reach unit, for third-party units, I can try my best . For now, it would be easier with a screenshot of its NTRIP settings. This may give me a clearer picture of the setup and allow me to offer recommendations.
