here is my latest simple dozer grading software
you can save the left and right to a .txt file to your downloads folder and rename it so when you save a other .txt file it doesn’t overwrite it, and you can load the file so you don’t have to manually type in the left and right every time you restart the program.
here is the nmea settings i use. (you can use bluetooth to)
you should see the blade on the program tilt now when you tilt the rover/dozer blade.
here is the python code
import pygame
import sys
import math
import serial
import serial.tools.list_ports
import threading
import pynmea2
import os
import time
from collections import deque
from tkinter import filedialog
import tkinter as tk
# --- CONFIG ---
FPS = 60
SCREEN_WIDTH, SCREEN_HEIGHT = 1280, 720
COLOR_BG, COLOR_PANEL = (35, 35, 35), (20, 20, 20)
COLOR_GREEN, COLOR_YELLOW, COLOR_ORANGE, COLOR_RED, COLOR_BLUE = (0, 255, 0), (255, 255, 0), (255, 165, 0), (255, 0, 0), (0, 100, 255)
COLOR_TEXT, COLOR_UI = (255, 255, 255), (60, 60, 60)
root = tk.Tk()
root.withdraw()
pygame.init()
screen = pygame.display.set_mode((SCREEN_WIDTH, SCREEN_HEIGHT))
pygame.display.set_caption("RS3 Machine Control - Pro Mode")
clock = pygame.time.Clock()
# --- FONTS ---
FONT_XL = pygame.font.SysFont('Arial', 75, bold=True)
FONT_MED = pygame.font.SysFont('Arial', 24, bold=True)
FONT_SMALL = pygame.font.SysFont('Arial', 18)
class GNSSManager:
def __init__(self):
self.elevation = 100.00
self.blade_roll = 0.0
self.mode = "SIM"
self.age_corr = 0.0
self.last_nmea_time = time.time()
self.ser = None
self.running = False
self.blade_l = 5.0
self.blade_r = 5.0
self.terminal_data = deque(maxlen=10)
def manual_save(self):
downloads = os.path.join(os.path.expanduser("~"), "Downloads")
path = os.path.join(downloads, "blade_config.txt")
try:
with open(path, "w") as f:
f.write(f"{self.blade_l},{self.blade_r}")
except: pass
def manual_load(self):
file_path = filedialog.askopenfilename(
initialdir=os.path.join(os.path.expanduser("~"), "Downloads"),
title="Select Blade Config File",
filetypes=(("Text files", "*.txt"), ("all files", "*.*"))
if file_path:
try:
with open(file_path, "r") as f:
data = f.read().split(',')
self.blade_l = float(data[0])
self.blade_r = float(data[1])
except: pass
def connect(self, port):
self.stop()
try:
self.ser = serial.Serial(port, 115200, timeout=0.1)
self.running = True
self.mode = "LIVE"
threading.Thread(target=self.read_serial, daemon=True).start()
except: self.mode = "SIM"
def stop(self):
if self.ser:
self.ser.close()
self.ser = None
self.mode = "SIM"
self.age_corr = 0.0
def read_serial(self):
while self.running and self.ser:
try:
line = self.ser.readline().decode('ascii', errors='replace').strip()
if line:
self.terminal_data.append(line)
if "GGA" in line:
parts = line.split(',')
if len(parts) > 13:
try:
age_val = parts[13]
if age_val:
self.age_corr = float(age_val)
except:
self.age_corr = 0.0
msg = pynmea2.parse(line)
self.elevation = msg.altitude * 3.28084
elif "$GNETC" in line:
if len(parts) > 6 and parts[2] == '30':
dir_rad = math.radians(float(parts[5]))
self.blade_roll = float(parts[6]) * math.cos(dir_rad)
except: pass
class ModalWindow:
def __init__(self, title):
self.active = False
self.title = title
self.rect = pygame.Rect(340, 110, 600, 500)
self.close_btn = pygame.Rect(880, 120, 40, 40)
def draw_background(self):
pygame.draw.rect(screen, (45, 45, 45), self.rect, border_radius=10)
pygame.draw.rect(screen, (100, 100, 100), self.rect, 2, border_radius=10)
screen.blit(FONT_MED.render(self.title, True, COLOR_YELLOW), (360, 130))
pygame.draw.rect(screen, (200, 50, 50), self.close_btn, border_radius=5)
screen.blit(FONT_SMALL.render("X", True, COLOR_TEXT), (895, 130))
class SerialWindow(ModalWindow):
def __init__(self, gnss):
super().__init__("Communication Settings")
self.gnss = gnss
self.ports = []
self.refresh_ports()
def refresh_ports(self):
self.ports = [p.device for p in serial.tools.list_ports.comports()]
def draw(self):
if not self.active: return
self.draw_background()
self.port_rects = []
for i, p in enumerate(self.ports):
r = pygame.Rect(360, 210 + (i * 40), 180, 35)
color = (0, 150, 0) if self.gnss.ser and self.gnss.ser.port == p else (70, 70, 70)
pygame.draw.rect(screen, color, r, border_radius=5)
screen.blit(FONT_SMALL.render(p, True, COLOR_TEXT), (370, 218))
self.port_rects.append((r, p))
self.refresh_btn = pygame.Rect(360, 430, 180, 40)
pygame.draw.rect(screen, (80, 80, 200), self.refresh_btn, border_radius=5)
screen.blit(FONT_SMALL.render("REFRESH PORTS", True, COLOR_TEXT), (385, 440))
self.disconnect_btn = pygame.Rect(360, 480, 180, 40)
pygame.draw.rect(screen, (150, 50, 50), self.disconnect_btn, border_radius=5)
screen.blit(FONT_SMALL.render("DISCONNECT", True, COLOR_TEXT), (395, 490))
term_rect = pygame.Rect(560, 210, 350, 310)
pygame.draw.rect(screen, (10, 10, 10), term_rect)
for i, line in enumerate(list(self.gnss.terminal_data)):
screen.blit(FONT_SMALL.render(line[:40], True, (0, 255, 0)), (565, 215 + (i * 22)))
def handle_event(self, event):
if event.type == pygame.MOUSEBUTTONDOWN:
if self.close_btn.collidepoint(event.pos): self.active = False
if self.refresh_btn.collidepoint(event.pos): self.refresh_ports()
if self.disconnect_btn.collidepoint(event.pos): self.gnss.stop()
for r, p in self.port_rects:
if r.collidepoint(event.pos): self.gnss.connect(p)
class BladeWindow(ModalWindow):
super().__init__("Blade Dimensions")
self.gnss = gnss
self.active_field = None
self.temp_text = ""
def draw(self):
self.field_rects = []
for i, (label, key, val) in enumerate([("Left Width", 'left', self.gnss.blade_l), ("Right Width", 'right', self.gnss.blade_r)]):
r = pygame.Rect(360, 210 + (i * 80), 200, 45)
color = (100, 100, 255) if self.active_field == key else (60, 60, 60)
screen.blit(FONT_SMALL.render(label, True, (200, 200, 200)), (360, 185 + (i * 80)))
txt = self.temp_text if self.active_field == key else f"{val:.2f}"
screen.blit(FONT_MED.render(txt, True, COLOR_TEXT), (370, 218 + (i * 80)))
self.field_rects.append((r, key))
self.save_btn = pygame.Rect(600, 210, 150, 45)
pygame.draw.rect(screen, (0, 120, 0), self.save_btn, border_radius=5)
screen.blit(FONT_MED.render("SAVE", True, COLOR_TEXT), (645, 218))
self.load_btn = pygame.Rect(600, 290, 150, 45)
pygame.draw.rect(screen, (0, 80, 180), self.load_btn, border_radius=5)
screen.blit(FONT_MED.render("LOAD", True, COLOR_TEXT), (645, 298))
if self.save_btn.collidepoint(event.pos): self.gnss.manual_save()
if self.load_btn.collidepoint(event.pos): self.gnss.manual_load()
for r, key in self.field_rects:
self.active_field = key
self.temp_text = ""
if event.type == pygame.KEYDOWN and self.active_field:
if event.key == pygame.K_RETURN:
try:
val = float(self.temp_text);
if self.active_field == 'left': self.gnss.blade_l = val
else: self.gnss.blade_r = val
except: pass
elif event.key == pygame.K_BACKSPACE: self.temp_text = self.temp_text[:-1]
else: self.temp_text += event.unicode
def draw_stacked_lights(x, y_center, offset, label=""):
light_h, light_w, gap = 25, 55, 4
colors = [COLOR_RED, COLOR_ORANGE, COLOR_YELLOW, COLOR_GREEN, COLOR_YELLOW, COLOR_ORANGE, COLOR_BLUE]
start_y = y_center - (3.5 * (light_h + gap))
for i in range(7):
light_color = (45, 45, 45)
if i == 3 and abs(offset) <= 0.05: light_color = colors[3]
elif i < 3 and offset > (0.4 - i*0.15): light_color = colors[i]
elif i > 3 and offset < (-0.05 - (i-4)*0.15): light_color = colors[i]
pygame.draw.rect(screen, light_color, (x, start_y + (i * (light_h + gap)), light_w, light_h), border_radius=2)
screen.blit(FONT_SMALL.render(label, True, (150, 150, 150)), (x + 5, start_y - 25))
screen.blit(FONT_SMALL.render(f"{abs(offset):.2f}", True, COLOR_TEXT), (x + 8, start_y + 210))
# --- MAIN SETUP ---
gnss = GNSSManager()
serial_win = SerialWindow(gnss)
blade_win = BladeWindow(gnss)
benchmark = 100.00
run = True
while run:
screen.fill(COLOR_BG)
events = pygame.event.get()
for event in events:
if event.type == pygame.QUIT: run = False
if serial_win.active: serial_win.handle_event(event); continue
if blade_win.active: blade_win.handle_event(event); continue
if pygame.Rect(230, 10, 140, 40).collidepoint(event.pos): serial_win.active = True
if pygame.Rect(380, 10, 200, 40).collidepoint(event.pos): blade_win.active = True
if pygame.Rect(1050, 10, 200, 60).collidepoint(event.pos): benchmark = gnss.elevation
if gnss.mode == "SIM":
keys = pygame.key.get_pressed()
if keys[pygame.K_w]: gnss.elevation += 0.02
if keys[pygame.K_s]: gnss.elevation -= 0.02
if keys[pygame.K_a]: gnss.blade_roll += 0.5
if keys[pygame.K_d]: gnss.blade_roll -= 0.5
# --- MAIN HUD RENDERING ---
pygame.draw.rect(screen, COLOR_PANEL, (50, 80, 950, 500))
pygame.draw.rect(screen, COLOR_UI, (1020, 0, 260, 720))
pygame.draw.line(screen, COLOR_GREEN, (130, 350), (890, 350), 2)
current_off = gnss.elevation - benchmark
rad = math.radians(gnss.blade_roll)
off_l = current_off + (gnss.blade_l * math.sin(rad))
off_r = current_off - (gnss.blade_r * math.sin(rad))
draw_stacked_lights(65, 350, off_l, "LEFT")
draw_stacked_lights(910, 350, off_r, "RIGHT")
center_x = 500
lx, ly = center_x - (gnss.blade_l * 40), 350 - (off_l * 100)
rx, ry = center_x + (gnss.blade_r * 40), 350 - (off_r * 100)
pygame.draw.line(screen, (255, 200, 0), (lx, ly), (rx, ry), 14)
pygame.draw.rect(screen, (255, 255, 255), (center_x - 10, 350 - (current_off * 100) - 15, 20, 12), border_radius=3)
# Header Buttons
status_col = COLOR_GREEN if gnss.mode == "LIVE" else COLOR_YELLOW
pygame.draw.circle(screen, status_col, (30, 30), 8)
screen.blit(FONT_MED.render(f"MODE: {gnss.mode}", True, status_col), (50, 15))
com_rect = pygame.Rect(230, 10, 140, 40)
pygame.draw.rect(screen, (60, 60, 60), com_rect, border_radius=5)
pygame.draw.rect(screen, COLOR_YELLOW, com_rect, 1, border_radius=5)
screen.blit(FONT_SMALL.render("COM PORTS", True, COLOR_TEXT), (com_rect.x + 15, 20))
dim_rect = pygame.Rect(380, 10, 200, 40)
pygame.draw.rect(screen, (60, 60, 60), dim_rect, border_radius=5)
pygame.draw.rect(screen, COLOR_YELLOW, dim_rect, 1, border_radius=5)
screen.blit(FONT_SMALL.render("BLADE DIMENSIONS", True, COLOR_TEXT), (dim_rect.x + 15, 20))
# Age of Correction Display
age_to_show = gnss.age_corr
time_since_data = time.time() - gnss.last_nmea_time
if gnss.mode == "LIVE" and time_since_data > 2.0:
age_to_show = time_since_data
age_color = COLOR_GREEN if age_to_show < 2.0 else COLOR_YELLOW if age_to_show < 5.0 else COLOR_RED
screen.blit(FONT_MED.render(f"AGE: {age_to_show:.1f}s", True, age_color), (600, 15))
# Sidebar Benchmark
pygame.draw.rect(screen, (80, 80, 200), (1050, 10, 200, 60), border_radius=8)
screen.blit(FONT_MED.render("BENCHMARK", True, COLOR_TEXT), (1075, 25))
# Bottom HUD
screen.blit(FONT_MED.render(f"GNSS: {gnss.elevation:.2f}'", True, (150, 150, 150)), (60, 610))
screen.blit(FONT_MED.render(f"GRADE: {benchmark:.2f}'", True, (150, 150, 150)), (60, 640))
msg = "FILL" if current_off < -0.05 else "CUT" if current_off > 0.05 else "ON GRADE"
color = COLOR_BLUE if msg=="FILL" else COLOR_RED if msg=="CUT" else COLOR_GREEN
screen.blit(FONT_XL.render(f"{msg}: {abs(current_off):.2f}", True, color), (445, 600))
serial_win.draw()
blade_win.draw()
pygame.display.flip()
clock.tick(FPS)
gnss.stop(); pygame.quit()
