RS3 + Fields Maps Issues
I have been attempting to use my RS3 with Field Maps for about two weeks now. I have attempted direct bluetooth connection as a location source, tried mock location with GNSS Master, and tried mock location with Lefebure. No matter what, I cannot obtain a fix to our base station.
In the Flow app, I am receiving corrections and obtain a fixed solution within 10 seconds. In Field Maps, no matter what, I am either in perpetual float or just maintaining a single solution (never improves past 20cm accuracy). What on earth am I doing wrong?
FYI, I am using a Samsung XCover7 (latest updates) and RS3 (32.2 Beta).
Hi @christopher.sperdut1,
It sounds like the issue is with the configuration settings between Field Maps and Emlid Flow. As @mahammadsutar81 has highlighted, there are a few you can check. For position streaming to Field Maps, you can follow this tutorial on its integration. We also have a step-by-step guide on Lefebure that you may find helpful in your setup.
If you can share the steps for your project and screenshots of your settings in Field Maps and Emlid Flow, we’ll better understand and know how we can help.
