No
As Iāve said previously, we have performed surveys on these sites without any trouble for over a year. Overnight, this problem has developed across multiple sites which is covered by the engineer using the same equipment, firmware and settings. The sites are dotted all across the north east of England and therefore it is not a localised issue. A new set of units have been supplied to the engineer, using the same settings and firmware and everything is working fine.
There seems to be a problem with this pair of RS2s.
Hi Dave,
According to raw data files received by email, both base and rover are affected by some strong interference or placed under an obstructed sky view. Take a look at them:
The rover log
The base log
There are many red bars which mean cycle slips. There are also blue and red strings that show low SNR values. Overall, it shows that the raw data has a poor quality which may be caused by the reasons mentioned above.
Furthermore, take a look at these base correction logs:
These gaps mean that the base stops sending corrections in these periods.
You can establish the connection between the base and the rover over NTRIP via Emlid Caster to check whether this issue is related to environmental conditions or the receivers itself. Youāll face the same issue if there are interference sources or obstructed sky view. If not, the connection will be stable and the rover will not lose the FIX solution on a long baseline.
If youāre entirely sure you donāt face this issue with another Reach RS2 in the same conditions, please send us the logs from them recorded in the same place. Iāll examine them and compare them with the logs from the units that bother you.
Hi Kirill,
Many thanks for analysing those logs. If I am able to, I will repeat this for another set of RS2s in the same conditions tomorrow and send you the logs.
Great! Iāll be waiting for them.
Hi Kirill,
I repeated the same test with a new set of RS2s and did not experience any problems, using the same settings and setting up the base station in the exact same location and I followed the same path with the rover unit and then walked further.
The log files have been emailed to you
If they receive anymore logs on this issue they could start a bonfire
Hi Dave,
I received those logs from Liam, thank you for that!
It may require a bit more time to check them out, but Iāll get back to you as soon as I accomplish.
Hi Dave,
Thank you for your patience!
The last raw data logs you sent are indeed of much better quality in comparison with the pair youāve reported.
In the Full system reports, I couldnāt find any signs of LoRa malfunctioning. But I agree that another pair shows completely different results in the same area. Maybe the root of this is in something else.
Another thought confusing me is that it is very unlikely that two devices start to behave that way without any apparent reason. To narrow it down, Iād test the receiver from the misbehaving pair with the receiver from the well-working pair. There will be two tests since there are two possible malfunctioning devices. Itāll show which one. It can be performed in another place if itās more convenient to you.
I have followed your advice. I carried out another 2 tests. The first test was using the base unit from the set which worked previously and the rover unit from the set which had issues. There were no problems.
The 2nd test involved the base unit from the set which had issues previously and the rover unit from the good set. The same problems occurred, so must be an issue with the base unit.
All the necessary files have been emailed to you for analysis.
Seems to me like thereās a hardware issue with one of the units?
Hi Dave,
I received the logs via email. Thank you for them!
It may require a bit more time for analyzing. As soon as I accomplish, Iāll reply to you in this thread.
Hi there,
We had a conversation with Daveās colleague over email, and Iām here to share the results. The last test helped us a lot. The issue turned out to be hardware-wise. We localized the malfunctioning unit and decided to replace it.
If you experience any issues with LoRa, please reach out to us via email or create a new topic. There may be a lot of different reasons, from settings to hardware issues. Each case should be considered separately, and weāre always here to help.
