I’m experimenting with RS2 Lora connections.
I notice the corrections for different constellations seem to alternate quickly on the rover side.
I used 1hz for all correction messages and the Rover RTK processing.
I use 5hz for the Base RTK setting.
With Ntrip correction input, I don’t experience this kind of flickering.
The solution seems not to be affected by this, I get solid fixes outside (screenshots are from inside).
Are you indoor or something? your SNR is not good.
Would give it another try in intended surroundings outside.
Base 1hz rtk,RTCM all 1hz and max speed on LoRa. 1 or 5hz on rover with the same LoRa setup
it’s indpor indeed. But flickering also appeared outdoors, still resulting in good fixes.
I’ll keep observing it with different settings, but not this week anymore.
Cheers
Have you been able to test the setup with different settings as @TB_RTK advised above? I assume there is might be something with update rate frequency.
Dear Tatiana, see above, i did test different combinations and did’t see a cleat pattern.
However this was all done inside.
I will do a more thorough test when I’m back at the office.
