Before creating a new thread please refer to Quickstart guides for Reach and Reach RS.
sorry if I open a new thread I can’t find information,
I have to do a job with RS2 only rover, but there is no possibility to use a data connection,
as I can proceed using the static mode, I can beat the points in static and perform a post processing on the data.
are there any guides?
thank you
Could you clarify whether you mean a mobile data connection?
To post-process the data, you need logs from the base and rover. You can still collect points with a single device, however, in this case, you can’t gain the centimeter-accurate coordinates.
I was referring to a mobile data connection.
how can I proceed with a single device?
do you have a guide to follow?
We have a tutorial about GPS post-processing in RTKLib. To accomplish it with a single device, you need to choose a Single positioning mode in RTKLib Options. However, please note, in this case, accuracy at the few-meters level.
Bear in mind, you can always submit your raw logs to a service like the NRCan PPP. You probably won’t be able to get sub-centimeter accuracy, but depending on your length of observation, you can get a quite accurate sub-foot location .
RS2 will give you 1-digit cm accuracy given long enough occupy time (12 hours +) and long enough wait until submitting (to get the Final solution).
But subcentimeter, nop, That’s usually within the tolerance of even your rover-rod at 1.8m extension
