With the last 2.7 version, I managed to link them over Lora radio, but I don’t know what is the best configuration to make the RS+ get a fix status from the RS2 as base.
Because of the messages being different for L1 and L2 it stays on float solution.
Any hints? A how to?
Thanks!!
I know @britopimenta had the same issue, but I don’t know if a solution was published in this community forum.
The baseline cors correction for the base at 3 km., urban environment. The rover was just at one meter from the base, Tomorrow I’ll try it in some other place with open space.
I agree with Christian, settings can hardly be a matter here.
RS+ is a single-band receiver, so the urban environment is not a good fit for it in most cases. To provide centimeter accuracy, RS+ should have a clear sky view 30 degrees above the horizon.
