the averaging started after the RS+ was centered over the reference point.
I finished my tests with the RS2 in the beginnt of this week on this points. I don‘t know when I could repeat this.
When I do, I will post the results.
Hi Florian,
If you face the issue again, please record position logs on the unit. They will help check the difference in coordinates in tests when you establish the connection to NTRIP in the building and on a point.
tomorrow I could repeat the test.
Please tell me exactly what I should do and which files do you need and where I find them.
this afternoon I could repeat the test.
Hi Florian,
It would be of help if you can collect position logs on the unit. You can start and stop logging in the ReachView 3 Logging tab.
Hi, I repeated the test with the RS2, but I could not reproduce the meter error. Test finished!
Thanks for the update!
