I have 2 Reach RS + units. Both units worked great off the start but now neither of them maintain good SNR. I will start out with a number of satellites in the green, in fact most of them. Within a minute or two they will start going to red and jumping in and out as red, green.
I cannot get a fix or even float status.
thanks for any help
Can you post the following things:
- raw file (ubx)
- images of your environment where the raw file was collected
- images of the unit itself, when it collected the data.
Then we can take a look.
Will do. Ill set up and go through with the base, where I set up one week and things were fine. The next week, over the same control I started having trouble not getting high enough SNR. I also set up both in the field next to my house a couple times with same result.
Hi @lonottosen,
I agree with Christian. To understand what causes the issue, weâll need raw data logs and photos of your setup and environment. Please keep us posted.
I set up this morning and tried to obtain a fix with one unit. I have included a photo of the setup and landscape where I was collecting data.
I also included logs. Let me know if I did not post the correct information.
thanks for any help.
Can you upload the ubx file as well?
It is not allowing me to upload attachments as I am a new user.
Just upload to a file-service like we-transfer or the like.
I emailed the UBX to your info dronographica email.
I am new here and could not figure out how to do it another way. Sorry if that is inappropriate way to do so.
Thanks for the logs!
Did you move or cover the unit around the 15:05 time mark ?
Lots of signals seem to suddenly loose some SNRâŚ
No I did not cover of move the unit. Any thoughts on settings or other things I can do?
I havenât looked at the files etc yet, but 1 thing I would definitely do is get the BASE higher. Add an extension to your tripod. I.e. 1â to 2â or so. It lets you also get the LoRa antenna vertically pointed down.
Also, try using BEIDOU instead of GLONASS to see if that helps.
Send your SIMPLE REPORT also.
Environment looks ideal⌠unless something with huge ElectroMagnetic Interference or High Voltage Power lines out of frame we donât see.
That is a good idea. Ill check into an extension.
The odd thing is I set up on a point and everything was working great. A few days later and ever since I have not been able to obtain even nail down âfloatâ.
Another question I have is one day I set up my base and input coordinates manually on a known benchmark. Oddly enough I had my rover about 50 to 70 meters from the base and the baseline readout was 7800.00 or so meters. Over 7000 meters baseline when I can see the unit?
You canât get a fix with one unit. Did you have a live connection to a base station somewhere? Or did you download some base station files to process against?
Yeah, I totally overlooked that statement. But either way, his original post states 2 RS+ receivers.
Needs to at least send the SIMPLE REPORT to help rule out the obvious.
Send SIMPLE REPORT for ROVER also. Keep in mind as @bide mentioned, you wonât get a FIX using ONLY the BASE.
In case BASE file expires:
Simple system report
app version: 2.18.1-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: B0:F1:EC:02:17:3E
security: wpa-psk
ssid: reach_base:1C:73
uuid: 24ae0bde-ce4c-4a9f-a6c5-62e15657d0f6
base mode:
base coordinates:
accumulation: '11.4'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: fix-and-hold
output:
enabled: true
format: rtcm3
path: lora
type: lora
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: true
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '1'
qzss:
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: '9.11'
frequency: 868000
output power: '20'
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: false
sbas: false
snr mask: '35'
update rate: '1'
Question. So in setting up my base, there are options for single, float, fix. After starting the unit it notes, waiting to fix. What your saying is that unless I also have a Rover set up and operating I will not get a fix on the base?
If I manually input coordinates of a known control point, my rover should pick up corrected information from the base correct? The issue I have when I do that is that my baseline shows something like 7000 meters greater distance than it actually is. Any thoughts?
OK. I think you are making some incorrect assumptions that need to be cleared up first.
One Reach RS+ that is operating by itself is a standalone GNSS reciever. It can achieve a position accuracy of about 2.5m when its position is averaged for under 5 minutes. The position it gets will be computed from its raw data log in what is called âsingleâ mode. That means it is acting alone, just like any consumer GPS (Garmin, etc.)
Next, if you have two Reach RS+, you can log the raw data on each unit simultaneously. Afterward, you can take the raw data log file from each unit and process them together to get a position accuracy of about 2cm. This techinique is commonly called PPK. Each RS+ is operating in âsingleâ mode, and the coordinates you see displayed in ReachView are not important. What is important is the raw data that is being logged and the results you get after processing. Afterward, when processing the raw data logs collected from both RS+, you must choose:
a) which RS+ you want to act as the base
b) which coordinates you want to assign to the base
The result of the processing will be a position log of the rover, and the coordinates in that position log will be about 2cm accurate in relation to the base coordinates. Think about the relation. If you accidentally used base coordinates that were 10m north of the actual base location, then your rover coordinates will still be 2cm accurate to the base coordinates, but shifted 10m north of the actual position. The accuracy that is achieved is the distance between the base and the rover. If you want global accuracy, then you must take it upon yourself to determine globally accurate coordinates and assign them to the base.
The last thing is RTK. In PPK, the PP stands for post-processing; the final position is computed later. In RTK, the RT stands for real-time; the final position is computed immediately. Before starting, you have to decide which RS+ will be the base, and decide which coordinates you will use for the base. If you donât already have coordinates or have the base set up over a âknown pointâ, then the easiest thing to do is take an âaverage of single positionâ for about 5 minutes. When that averaging is finished, now you have a âknown pointâ. It may only be globally accurate to 2.5m, but if you reuse those coordinates every time you place your base on that point, your rover will be accurate in relation to that point and it will be repeatable each time you survey out from that point. Once the base coordinates are set, the base can be used to send a stream of data that is commonly called âcorrectionsâ. The rover recieves this stream of correction data in the form of RTCM3 messages, usually by LoRa radio. It could also be sent over the Internet, or Wi-Fi, etc. The rover then uses those RCTM3 messages to live-process its final RTK position. On the base, ReachView still shows âsingleâ mode and the coordinates shown there are not important. But on the rover, you should see a status of âfloatâ, then âfixâ and that is when you can expect that the coordinates can be getting to about 2cm accuracy.
p.s this is all in the documentation, including the part about placing the base: Placing the base | Reach RS/RS+
there you can see other options for getting a more accurate base position.
