Hello Everyone
Is there a difference between using RINEX 3.03 generated from the Emlid RS2 Logging and using UBX raw data files converted to RINEX in RTKConv?
Hello Everyone
it’s the same file, ubx takes up less memory on the device
Adriano,
You can go either way, the resulting file should be the same
However, it seems that this full menu is not digestible.
I see, i normally work with ubx files so i can be more flexible with the convertion. Thanks!
Here in Brasil we still work with RINEX 2.1 for PPP, also for older Post-Processing softwares are very popular amongst smaller companies that work with RTK and PPK.
