I have an issue with the amount of NMEA messages being output by the Reach unit, it is being used for monitoring vehicle movements and is reporting to AWS. The amount of messages being sent is increasing the AWS costs and making the solution expensive.
Is there a way to restricting the NMEA messages to 1 per second, we seem to be getting a lot more than this.
Please reduce your update rate to 1 Hz. NMEA contains a lot of information apart from the solution. If you are only interested in the position, I would suggest switching to LLH, which is much more basic.
