Software
I have 2 reach units. One works and the other is giving me the worst time ever!
i can find the reach AP and connect to it. Going to 192.168.42.1 to add new wifi network. I click add and enter the details of the wifi network, then click done. Usually you get the name of the network, which you click and connect to. However, i dont get anything…just the same start page when i enter 192.168.42.1
I re-enter the wifi network again, and again nothing…
I tried reflashing with intel’s tool…FAILED
i tried reflashing with the ./flashall.sh command …FAILED
the flash.log last few lines:
Filter on vendor = 0x8087 product = 0x0a99
Opening DFU USB device... ID 8087:0a99
Did not find cached descriptor
Warning: Assuming DFU version 1.0
Run-time device DFU version 0100
Found DFU: [8087:0a99] devnum=0, cfg=1, intf=0, alt=7, name="rootfs"
Claiming USB DFU Interface...
Setting Alternate Setting #7 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 4096
bytes_per_hash=16318279
Copying data from PC to DFU device
Starting download: [#############################dfu_download: libusb_control_transfer returned -7
Error during download
can't detach
Resetting USB to switch back to runtime mode
Also, i cant ssh into the unit! After i enter the password after ssh, i get nothing…
the reach unit keeps blinking red, green.
I am running ubuntu 14.04. Using reach image 2.3
Any ideas? Anyone faced this before?
[EDIT 1]: showing output of Intel platform flash tool lite
03/22/17 15:49:37.707 WARNING: [Port 1] Command `"/opt/intel/platformflashtoollite/bin/dfu-util" "--alt" "u-boot-env1" "-D" "/home/ahmad/rtk_reach/ReachImage_v2.3/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99" "--path" "3-1"` failed
03/22/17 15:49:37.707 INFO : [Port 1] Retrying `"/opt/intel/platformflashtoollite/bin/dfu-util" "--alt" "u-boot-env1" "-D" "/home/ahmad/rtk_reach/ReachImage_v2.3/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99" "--path" "3-1"` command
03/22/17 15:49:37.835 ERROR : [Port 1] Command `"/opt/intel/platformflashtoollite/bin/dfu-util" "--alt" "u-boot-env1" "-D" "/home/ahmad//rtk_reach/ReachImage_v2.3/u-boot-envs/edison-blankcdc.bin" "-t" "4096" "-R" "-d" "8087:0a99" "--path" "3-1"` failed
03/22/17 15:49:37.835 ERROR : [Port 1] Flash failed (Command type: DFU)
03/22/17 15:49:49.749 INFO : [Port 1] Device lost on 1
03/22/17 15:49:51.761 INFO : [Port 1] New device detected on 1 (id=0100000000000000)
03/22/17 15:49:55.795 INFO : [Port 1] Device lost on 1
[EDIT 2]
the reach unit now only flashes red and green. no AP no noting…
