We’re using a Reach on a quadcopter, with an LTE modem/router for all our comms. The problem I’m having is that the Reach boots up more quickly than the modem/wireless AP and goes into hotspot mode before the AP SSID is visible. I can force a reconnect through the web interface but it’s annoying to do this every time I power up the aircraft. Is there any way to set a dwell/retry time before Reach goes into hotspot mode?
I’m sure you could insert a sleep 60 command somewhere in the startup process. Who knows if you can guarantee it will stay persistent after software upgrades though.
I would like to do the same with a mifi router.
Next thing would be to link the voltage wires of a male micro USB to the NO and COM output on that delay module?
Yes, I think you could buy a USB short extension cable and snip the +5 Volt wire and put each side of it into the NO (normally-open) and COM (common) just as you said.
