I plan to use Reach out in the field far from a wifi source and my phone is not setup to be a hotspot. Even if it was most locations I will be going do not even have cell service. Can I just use the Reach hotspot to use the Reachview app?
Yes, you should be able to… I can.
Yes, you can use it that way. Actually, yesterday we have been flight testing Reach with an autopilot and I was able to have connection to ReachView within approximately 25 meters.
If Reach does not see a familiar network it will switch to hotspot mode and ReachView will always be on 192.168.42.1 .
Most current version and related changelogs are listed here.
I was worried that if I set the wifi to my home router I would be prohibited from using from using the reach hotspot out in the field. All is good and working well so far!!
Thanks!
Is there a way to get notified once reachview version gets updated.
I see i have been working on an older one (0.2.2).
@TB_RTK yes, we are working on auto-notification. Every time Reach would have internet access it will check for the new version and notify the user. The feature should be released in one of the future updates.
