I haven’t been using my reach rs2 much ever since i bought it.
but recently i started putting it to survey work but i would say am rather disappointed in the equipment coz whenever am working outside and the temperatures reach 40 degrees , it loose satelites completely , this happened both when am using it as base and another time when am using it as a rover .
Now yester day i took it to field to pick a topo of an area of a plot of 13decimals but am disappointed to find out that all the data i have picked was wrong !!!
the data is confined with in a radius of 1.5meters yet i traversed the whole plot of 13 decimals. And all the elevations are almost the same yet the area is sloping at a slope of 10%…
EMLID I NEED ANSWERS.
Simple system report
app version: 30.0-r2
current_network:
ip: 192.168.43.165
security: wpa-psk
ssid: BV4900
enabled: true
mode: client
base_mode:
base_coordinates:
accumulation: 5
antenna_offset: 0
coordinates:
height: 0
latitude: 0
longitude: 0
mode: single-and-hold
output:
io_type: ntripsvr
settings:
lora:
air_rate: 9.11
frequency: 868000
output_power: 20
ntripcaster:
mount_point: REACH
password: '***'
port: 2101
username: reach
ntripsvr:
address: 164.90.243.252
mount_point: MP215a
password: '***'
port: 2101
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1004:
enabled: false
frequency: 1
message_1006:
enabled: true
frequency: 0.1
message_1008:
enabled: false
frequency: 0.1
message_1012:
enabled: false
frequency: 1
message_1033:
enabled: false
frequency: 0.1
message_1074:
enabled: true
frequency: 0.5
message_1084:
enabled: true
frequency: 0.5
message_1094:
enabled: true
frequency: 0.5
message_1124:
enabled: true
frequency: 0.5
message_1230:
enabled: true
frequency: 0.1
bluetooth:
enabled: true
pairing:
discoverable: true
no_input_no_output: true
pin: '***'
correction_input:
base_corrections:
io_type: bluetooth
settings:
bluetooth:
send_position_to_base: false
lora:
air_rate: 9.11
frequency: 868000
output_power: 20
ntripcli:
address: survnet.xyz
mount_point: RTCM3X
password: '***'
port: 2102
send_position_to_base: true
username: MATOVUFRED
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
privacy_policy_accepted: true
role: null
rv3_banner_shown: false
usage_analysis_accepted: true
logging:
logs:
autostart: true
base:
enabled: true
format: RTCM3
raw:
enabled: true
format: RINEX
rinex_options:
logging_interval: 0
marker_name: null
pole_height: null
preset: default
satellite_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
sbas: false
time_adjustments_enabled: true
version: '3.03'
solution:
enabled: true
format: LLH
started: true
settings:
interval: 24
overwrite: true
simultaneous_logging: false
network:
tcp_over_modem: false
position_output:
output1:
io_type: bluetooth
nmea_settings:
bluetooth:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: tcpsvr
nmea_settings:
bluetooth:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
ebp:
enabled: true
update_rate: 1
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
positioning_settings:
elevation_mask_angle: 15
glonass_ar_mode: false
gnss_settings:
positioning_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
update_rate: 5
gps_ar_mode: fix-and-hold
max_vertical_acceleration: 1
positioning_mode: kinematic
snr_mask: 35
sound:
mute: true
volume: 100
