Has anyone managed to create a successful workflow for using a Reach RS2+ as a base and a Topcon Hiper V as a rover.
Hi @wrussel,
If your Topcon rover supports RTCM3 corrections, it should work fine with Reach RS2+. Here’s the list of the messages it outputs as a base:
You have two options for using a Reach RS2+ as a base and a Topcon Hiper V as a rover:
- You can use a pair of 3rd-party radios to connect both your receivers.
- You can work with our Emlid NTRIP Caster. It’s available for free and works worldwide. This guide will help you set up both your receiver.
