I use reach module and reach rs module,they are the same set all through Ntrip receive rtcm date,the reach can receive date and AR is 999 fix,but the reach rs can’t display grey pillar and AR date is zero。so i used two reach rs module to worked is RTK mode,there is same problem reach rs can’t display grey pillar and AR date is zero,but in the correction input can display rover reach rs have received rtcm date。
This is the setting of the reach rs,but the picture can’t display grey pillar and AR date is zero。
This is two reach rs connection through Lora wireless ,it’s the same as the ntrip above, the reach rs rover module can’t display grey pillar and AR date is zero ,but in the correction input case display have received rtcm date。
