I haven’t used my two Reach units much this year.
Earlier I did try to upgrade the firmware and it failed on both units. It was a beta version. I went back to v1.2 on both units and they worked again fine.
Now I tried to upgrade again. The one unit worked perfectly with 1 try. The other however has gone from bad to worse. I had trouble reflashing it with an Ubuntu machine. I could flash it and give it my network name but it would never join my home network. It would show up as usb0 and once I started a SSH session but didn’t get anywhere. The one quirk that was consistent was that I never had to enter the password when connecting to it’s hotspot. It was able to get reflashed, boot and establish it’s own hot spot but never join the local network, well except once. There was one glimps of hope when I was able to get it flashed with v2.3 and it rebooted and did a full update over the internet. Even this time it did not ask me for the password when I connected to it’s hotspot but it looked like it was going to work. I then took both units outside and started them up. The “broken” one would only create a hotspot. I tried reflashing it many times with different cords and from a Windows machine and a Linux machine. It got to the point now that the computer won’t recognize that a USB device is connected. No usb0 on Ubuntu and when I plug it into Windows it flashes twice that something is connected but then it goes away. Below is a link to a 15 sec. video trying to show the LEDs once powered up. When reflashing with Ubuntu there are no error messages during the process but I can’t believe it is working correctly since when I plug it back in and type ifconfig I get no usb0.
https://my.pcloud.com/publink/show?code=XZQQ9iZ7lByllESkfmG6QtOAU6OsSYpNeey
Is there anything I should try?
Thanks,
Robin.
