I am trying to do a simple soft reboot on the REACH. So far I have tried both using ssh as administrator, firing the ‘reboot’ command and through the web interface. In both cases, the REACH will reboot, but does not startup correctly. The LED shows constant red and the reach does not start generation position output, logs, etc. The problem seems to be present both in Base and Rover mode.
Any suggestions? Does anyone experience the same problem?
