Hi
thanks for the support so far. ive received the replacement unit on 31st dec 2020. however i had encountered this problem after updating the firmware. I have updated to v2.24.2
is this normal?
thanks
remi
Hi
is this normal?
thanks
remi
From your video I am still not sure what the issue is. Can you make a more detailed report in writing here?
Hi @remi,
As I can see from the video, the gray bars indicating the base’s satellites are jumping up and down sporadically. Is it the issue you wrote about?
What do you use as a corrections source? Is it an RS2 unit transmitting RTCM3 messages via LoRa?
yes. that is the issue. i think someting is not right somewhere.
i am using ntrip connected to a gov correction server. i guess it is connected via web right?
thanks for spotting the error.
Yep, that should be so.
Could you please post a screenshot of the Correction input tab while Reach is connected to an NTRIP? Please click on the “∨” button located right from the Connected string. It will allow me to check the RTCM3 messages that are coming in.
