Hello
I have an M2 installed in a Phantom 4 pro. I have not tried to connect to M2 for more than 8 months but I flew the Drone for fun. Today I wanted to connect to M2 just to make updates but there is no way to connect to it. No Access Point, no connection via router. M2’s Bluetooth can be found but does not connect to smartphone.
Should I remove the M2 from the drone and do specific actions?
If the LED is solid, you can connect to Reach as shown in the First Setup guide. For Android, please ensure mobile data is turned off.
If the LED blinks, the receiver is connected to external Wi-Fi. Can you see this Reach in ReachView 3 when your smartphone is in the same Wi-Fi network?
Finally, before an hour I managed to open the body of Phantom 4 and removed the Reach M2. I plugged it to my PC via USB mini for power. I do the updates by mobile phone connection and later will try to see if with the same drone-internal cables the problem will remain.
