- firmware image / ReachView Version
root@reach:/# cat /etc/issue
Poky Neutis (Emlid Neutis Linux Distro) 0.1.4-dev \n \l
Simple system report
app version: 2.16.2-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.43.127
is_added: true
is_connected: true
is_visible: false
mac_address: AC:83:F3:1F:0D:ED
security: wpa-psk
ssid: MaproomAP
uuid: e8784288-c34b-47e4-9104-ae9569a9c560
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: tcpsvr://:9002#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: true
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: true
format: erb
type: serial
output2:
enabled: true
format: nmea
path: :9000
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: true
gps: true
qzss: true
sbas: false
snr mask: '35'
update rate: '5'
- problem description
I’m trying to install nodejs via opkg:
root@reach:/# opkg install nodejs
Collected errors:
* opkg_prepare_url_for_install: Couldn't find anything to satisfy 'nodejs'.
Trying to update opkg sources yields the same results:
root@reach:/# opkg update
Downloading http://files.emlid.com/reach-plus/stable-repo/neutis_n5/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Downloading http://files.emlid.com/reach-plus/stable-repo/aarch64/Packages.gz.
Downloading http://files.emlid.com/reach-plus/stable-repo/all/Packages.gz.
Collected errors:
* opkg_download_backend: Failed to download http://files.emlid.com/reach-plus/stable-repo/neutis_n5/Packages.gz, wget returned 1.
* opkg_download_backend: Failed to download http://files.emlid.com/reach-plus/stable-repo/aarch64/Packages.gz, wget returned 1.
* opkg_download_backend: Failed to download http://files.emlid.com/reach-plus/stable-repo/all/Packages.gz, wget returned 1.
Not sure how to proceed, please advise
