I had configuration problems with my UART to ethernet converter and I’d been busy with other things, but I was finally able to test the setup for a day and it worked fine, stayed on fix all day.
@zoltan.biber, would you mind if I set my previous post as the solution for the topic for simplicity’s sake, even though you were the one that found the problem?
