I am working on integrating the Reach Module on a rover with a Raspberry Pi running ROS. I would like to take advantage of the ROS navigation stack and possibly the MoveIT movement planning framework.
Has anyone else started this type of work - i see that there is not that much mentioned on the ROS site regarding RTK in general or Reach.
Also looking at similar as I dive into ROS. I’ve got my reach plugged into a Navio2 w/ ROS and can see it as GPS2 and confirm that it’s being corrected from my Base. So I can access it through MAVROS, are you not going to use that and instead use http://wiki.ros.org/navigation?
Hmmmm actually as my Rover is a slow moving ground unit which I am implementing a CCPP algorithm for I believe I do not have that much use for the navio nor MAVROS.
What i am after is something quite similar to the Swift Navigation’s Piksi RTK GPS receiver ROS Package: http://wiki.ros.org/swiftnav_piksi - but for the Reach naturally.
