I want to make a fault report on the reach rs antennas. Since the last update (2.11) and reachview 1.3 have been failing. I did not have any of those faults with the last updates (Stable).
In reachview constantly shows the message of lost signal with my antenna, although reachview at all times is active (I do not let the screen of my cellphone come to rest) and my antenna is two meters away on the stick.
When I’m doing rtk I see that I have “fix” at all times in my route but to see the map in reachview shows that there was loss of signal between base and rover, there are straight lines of gray in my path.
The hotspot of my antenna also fails, there are times when turning on my antenna (rover) I can not find it with my cell phone’s.
Yesterday, for example, when I was doing rtk (LoRa) the hotspot of the rover stopped working and at another time it worked normally. I can not confirm if my base antenna has the same problems since I leave it alone at a known point.
Anyone else have similar problems?
