I was wondering If its possible to work in PPK mode with only 1 RS2+ and how can I do it … I cant find response
Single point or a survey session? You can do logging and maybe download the Rinex from a CORS. TXDOT posts their hourly logs so maybe someone where you are does as well.
Hi jgarcia, it is possible depending on where you live and if you are within range of a CORS type system so you can download the Base logs from the CORS system for use in Emlid Studio.
I assume most likely you would be doing a kinematic type survey and not a 4hr Static type survey. If you are doing a kinematic type, you would want to follow the Emlid advice here:
How to log data for Stop & Go with ReachView 3
and then process the files using this information from Emlid here:
Substitute the CORS files as your Base and use your RS2+ files as your Rover.
Again, this is assuming that you have access to CORS type solution or a private provider solution .
Hope that helps
First thanks a lot to both of you. I live in south spain and we have the RINEX files from IGN and RAP. My purpose its for kinetic surving of a big measurement (50 ha). If I’ve understand what you’ve write, YES its possible. I will try your indications. Its my first time with a GPS. All the time before I’ve been workin with Total Station TOPCON GTS. Now Im very happy with both. GPS its a new world for me. Thanks to Emlid too.
