I have a five Reach M+ and i am experiencing issues with it when updating to firmware version v2.22.3, using the update procedure by going to port 5000. I have updated three of my boards, and currently I have one that working properly (and indicating that firmware version is indeed V2.22.3. And I have two that are not working anymore.
I am not sure what this means, could it be possible that the device has been bricked due to the update? Since the hotspot or wifi is not coming up I have to way to connect to the device and check the status.
It seems that this has been coming up more lately, but mine was due to my source not supplying enough power. Have you tried connecting a mobile device charger? Also, hit the reset button
Seems that I have the same problem.
i update through the first webpage and a hotspot to 2.22.3. After a reboot the green led blinks and I can’t access to the webpage.
Should I reflash it with the latest 2.22.2 with the image?
Is your Reach connected to the Internet? Blinking green LED usually stands for time sync. Make sure you have the Internet access or provide a skyview to the unit with the connected antenna
