I too am looking at hacking my QX1, but $400US on top of sending it to the states to have it done does not excite me. This site has the hack listed at $150US but Iām still awaiting a reply
Ya, the $400 upgrade for the QX-1 trigger doesnāt excite me either. That price is steep and what concerns me most is that I then have a $1000 (Canadian Pesos) item sitting in my drone. And I have to admit that I often land my drones HARD or gasp every now and then they fall out of the sky!! Iām still waiting on my Reach GPS (over 3 weeks since order and Emlid is not responding to emails!) so I can conduct some tests to see what the difference to reality is? If the time difference between the shutter and gps mark is constant could an approximate XY offset be calculated using ground speed and track?? In 95% of my mapping jobs having 10-20cm overall accuracy would be good enough.
The other option I am working with is to use a larger plane like a Skyhunter or Talon so I can use another camera (that would accept the TuffWing Reach hotshoe cable) that would fit in landscape mode in the fuselage. I am currently working on trying to trigger a Canon EOS M from my Pixhawk using the Tragic Lantern hack (works thru the microphone jack).
In regards to a QX-1 gimbal I am in the early stages of designing a 1-axis roll gimbal for use in my SkyWalker. This is a simple 3d print job. Should be easy. Just need to find some time to finish it. I donāt think the 2nd axis for pitch is necessary.
It seems, from my research, that the only safe game in town for getting the QX-1 modded is the $400 option from the ES38 folks. I think it is very easy to brick this camera trying to mod it yourself - unless one knows what they are doing!
I have been using the Seagull #map2 trigger for the QX-1 with Pixhawk prior to just receiving my Reach GPS. Now I am wondering if there is any way to somehow integrate the #map2 trigger with the Reach?? Iām completely new to the Reach so havenāt had the time to look into how trigger marks are imprinted on the raw GPS stream. Until then I am going to order the Tuffwing hotshoe connector-thing and experiment with my NEX-5n and EOS-Mā¦
