OPUS abort during Rapid Static
I tried to process an RS3 RINEX file through Rapid Static on OPUS this week but OPUS keeps aborting the process and just sends back an email with the information shown below. The duration is 1:46 so went with Rapid Static vs standard. Emlid Support reviewed and found no issues with the file, also uploaded it to OPUS and had the same abort issue. I frequently upload to OPUS standard Static and never have had a problem. Anyone else run into this issue with Rapid Static? Thanks.
OPUS-RS aborting : ReachBase_raw_20250426152208.25O OP1746739070296
FILE: ReachBase_raw_20250426152208.25O OP1746739070296
                              RSGPS OUTPUT
VERSION= rsgps version 1.38 2017 05 26
Run Date and Time = 2025 5 8 17 21 8
Project Directory = /var/tmp/opus_local/RS291/25116/
Solution Mode = network
W-Ratio test indicates SUCCESS!
Observations Used/Available= 8202 10506
Network Quality Indicator= 5.31
RMS= 0.417
You should have received the possible causes for aborting in the email also? Possibly starting with 6034? If so, add that to your post.
We have been communicating via email with @SteveB. Hopefully, other users can share their experiences when trying to process in OPUS, especially when the process aborts without providing additional information on the reason for the failure.
Opus and Opus Beta do not accept large files or observations stamped with decimal seconds.
Try using Emlid Studio to export a copy of your RINEX file. You can use the “Logs duration” option to trim unwanted noise or movement at the ends (e.g. during setup or takedown), to reduce file size by choosing a 10, 15, or 30 second interval, and to round the decimal seconds to integer seconds.
I hope that helps.
