Hi Tatiana, all it does is not show a mount point. Every thing else is identical.
There are no instructions anywhere about how to set the RS+ up to use a hotspot. Do you have a set of instructions so that I can set it up properly and then see if it works?
You can connect Reach to iPhone hotspot in ReachView Wi-Fi tab. Once Reach RS has the Internet connection, you’ll be able to receive NTRIP corrections.
