After updating the firmware to version 2.22.3, the performance in NTRIP mode, was very bad.
Hardly fixed.
I tested 4 Emlid RS2 receivers in a completely open place with the base 10 KM.
Before upgrading to version 2.22.3, the signal was easily fixed in the same location.
Now NTRIP is very complicated after updating to version 2.22.3.
What can be done?
Would you mind providing the raw data logs, base correction logs and position logs from the receivers? Would it be possible to share the logs from the previous version so that it’s possible to compare them?
It’d also be great if you could upload the photos of the environment you’ve had issues with establishing a fix in.
