Hi. Sometimes I work in areas where the NTRIP coverage is not very good and I lose the connection and the position is no longer fixed, but the problem is that when I return to areas where there is a good connection again NTRIP does not connect me automatically, I have to access When you reach the viewpoint and in Correction Input, select the Mount point again, is there any way to automatically reach reconnect when I have a good NTRIP signal again?
Sorry for the delayed reply.
Unfortunately, I haven’t managed to reproduce this issue. I tried turning on/off mobile data while Reach is connected to NTRIP, and it reconnected successfully.
Could you please describe your current setup? What Reach model and software version do you use? How do you connect Reach to the Internet?
