Have this message , and is in red ? What ist the problem ?
Another issue is the wifi spot (reach xxxx) that have no internet access.
In the wifi menu on the reach. iI tried to connect to a wifi adn I cant reebot the program ?
Hello,
Are using Reach in hotspot mode? If you want to use NTRIP corrections, you will need to connect Reach to a Wi-Fi network with Internet access.
It is fixe now but connected to host and in Kinematic, get no fix only float ?
