I use the service only rover ntrip receiving RTK Corrections over the Internet, in the base mode tab I have disabled the correction output.
In the base coordinates tab, what should I choose (single average, float or average correction)?
Not clear how your setup is. Do you have one or two Reach units?
One Reach RS2
OK, so you want to create a new known point or survey by connecting RS2 to ntrip?
If so, this guide should help you.
I read the guide and it work, but I don’t understand if I must also set the base coordinates tab. Do I leave single average (default)?
No, you dont need to set base with any settings.
Ok, so base mode corrections output off and coordinates tab “default” single average.
Yes
Thanks for reply.
