When running corrections via NTRIP, when collecting GCPs and it’s calculating the RMS, does it reflect the true RMS based on the mm plus ppm accuracies?
I think what you see in surveying page is precision. Accuracy can only be calculated if you know the true coordinates of that point. We might say expected accuracy of RTK is 2cm or less.
Hi Seth,
Could you please elaborate more on what do you mean by true RMS?
Root Mean Square (RMS) is a statistical measure of precision, which shows the spread of the results at a certain confidence level. In simple terms, RMS value displayed in the Survey tab doesn’t consider ppm value.
