The solution is to ONLY select logging UBX. Then you can use Emlid Studio to generate a Rinex file if you need it. For processing Lidar, it is vital to have the UBX file (at least for the Inertial Labs units). So I am not aware that it has been fixed.
Hi everyone,
The fix for the UBX file not being generated should be fixed in the 32 Beta version. Please update the receivers to check if the issue is fixed.
However, please keep in mind that this is a Beta version, which provides early access to new features only.
