Maximum output rate for NMEA messages
I’m currently using a Reach RS3 connected via USB to PC, and I’m streaming NMEA messages (GGA and RMC) for real-time geotagging of images captured at 60 FPS.
In the ReachView configuration interface, I noticed that the maximum output rate for NMEA messages is limited to 10 Hz, and I understand this is due to internal GNSS solution update rate constraints.
My question is:
Is there any way to increase the effective positioning rate beyond 10 Hz
My goal is to minimize the georeferencing error between GNSS updates and 60 FPS image frames (~17 ms/frame)
Thanks
Probably not, especially after the max rate will be sacrificed ftom 10Hz to 5hz with a new update for new dual channel feature?
You may want to look at the new Ublox X20 or Mosaic X5? I would assume the next Emlid version would incorporate the X20 but who knows.
Hi @meriemka,
Welcome to the Community!
@timd1971 is right. The maximum update rate is 10 Hz and cannot be increased. Would interpolating positions between GNSS updates work for your application?
