Hi, I am having trouble getting my M2 to fix solution, it is only staying in float solution.
I am using a RS2+ as the base average singled sending LoRa correction. Both units are up to date with the latest firmware. I have tried increasing the Lora correction link to 18 kbps and disabled and enabled different RCTM3 messages. Nothing seems to changing the solution.
I am using the M2 with a DualEm for doing point measures in a paddock. When the trigger is pressed it records the Duelem values and coordinates via the M2.
Any help would be appreciated.
Hi @cameron.silburn,
Were the base and the rover provided with a clear sky view? If not, could you please test it outside in an open field?
Also, do you get the same results if you use Emlid Caster to pass corrections to your rover?
Hi Ruth,
Yes clear view of the sky.
I have tried the caster option, however still didn’t get a fix.
The M2 is now showing a fix on the app but the Duelem which is recording the data doesn’t record it as a FIX position.
If you can get a FIX using Emlid Flow and it doesn’t show in the third-party app, then I believe there’s nothing wrong with the M2 or antenna.
The issue seems to be with the integration between M2 and Duelem. How do you integrate M2 into this app? I can’t find any documentation regarding this. Thanks!
Yep, I have come to the same conclusion as well. It is a custom design so there won’t be any instructions online. I will get in contact with the creator to help me solve it.
Thanks for your help.
Cheers!
