Hi, can I use an old L2 survey antenna for the M2? I have some old L2 GPS antennae from old Ashtech & Topcon receivers that I am no longer using. I was wondering if I could repurpose them for the M2 instead of buying new antenna.
It completely depends on the bands the antenna is tuned to receive. It needs to be able to receive these bands:
GPS/QZSS L1C/A, L2C
GLONASS L1OF, L2OF
BeiDou B1I, B2I
Galileo E1-B/C, E5b
Hi Juan,
You can use multi-band GNSS antenna powered with 3.3 V that supports the bands Christian mentioned. You can find more information about supported signals in the specification.
Please note that the antenna connector is MCX. You can use an adapter to connect to SMA or TNC antenna cable.
Thanks for the replies guys. Stay safe everyone
