Logs Base – error GLONASS
Reach RTK
Reach View 2.22.4
GLONASS lacks in the log of the base but the data NMEA seems to be correct.
base_202005200900_RINEX-3_03.zip (837.5 KB) base_202005200900_rtcm3.zip (1.1 MB) raw_202005200900_RINEX-3_03.zip (3.8 MB) raw_202005200900_ubx.zip (4.3 MB) solution_202005200900_NMEA.zip (416.3 KB) simple report.zip (1.1 KB)
Hi Pawel,
Thanks for sharing! I’ll look into the data.
Error in ReachView 2.22.4 he is the most probably. ReachView 2.22.3 ok.
base_202004161044_RINEX-2_11.zip (2.5 MB) base_202004161044_rtcm3.zip (2.3 MB)
Hi Pawel,
I’ve checked the data and the GLONASS L1 observations are present. It seems they indeed aren’t shown when the β€œAll” option is chosen, however, if you chose β€œL1”, you can see GLONASS satellites:
Any chance you can share the UBX file from the base? I’d like to look into why RTKPLOT interprets obs file from v2.22.4 this way.
Hi Tatiana
thank for the interest oneself this subject. I also already noticed that you can see GLONASS in β€žL1” . I sent all logs from the measurement from the day 20-05-2020. My base is VRS (by NTRIP).
However I would prefer to analyse the different example
base_202005080758_RINEX-3_03.zip (865.4 KB) base_202005080758_rtcm3.zip (1.2 MB) raw_202005080758_RINEX-3_03.zip (5.3 MB) raw_202005080758_ubx.zip (6.1 MB) NMEA.ZIP (848.7 KB)
