Location data lost
I am using reach m2 as rover and I monitoring that location. Sometimes location data lost in 1 sec. and taking location again.
is that lost location problem from base stasion? or under voltage?
Hi Nasimxon,
Can you share a screencast showing this issue with me? Also, please describe your setup (are the units connected via the LoRa radio or NTRIP, the baseline value, the firmware versions installed)
To check if this behavior is related to the correction transmission or GNSS reception quality, I’ll need these logs collected for 10-15 minutes:
  • raw data logs from the base and rover
  • base corrections log from the rover
  • position log from the rover
Hi Nasimxon,
How is your work with Reach going? If you have the logs and the screencast, please share them with me.
