I have a new RX (MFi) updated to firmware v1.8.
I’d like to be able to record a gps track on my iPhone using the RX GPS data. This seems to be remarkably hard to do!
Are there actually any ios apps that can pull data from the RX?
I’ve connected Emlid Flow and the “integration with external software” info helpfully says “any” software that can take NMEA format data will work with the RX but I’ve tried about 5+ apps and non of them detect the receiver or use the RX data.
For apps that are listed as actually working with the RX:
Survey123 (arcgis esri) never finds the Device:
- Select “add location provider” → Bluetooth → Discover
- wait… times out and “discover” turns off
- Repeat until you give up
Pix4d catch - connected once out of about 10 tries, connection is too unreliable to be used
Are there actually any apps that work with the RX natively on iOS?!
I’m not trying to do any fancy surveying tasks at this point, just want to collect a GPS track with RX quality data.
