I am trying to run ROS in raspberry. When i try to install rviz with sudo apt-get install ros-kinetic-desktop-full i get Unable to locate package ros-kinetic-desktop-full error. It cannot find the package. Does it work only Ubuntu16.04 ?
Hello,
According to this page, Navio Raspbian image comes without GUI, so there is no option to run rviz, even if you install it.
Either way, there is no simple way to install ROS on Raspberry Pi, please refer to this guide. (If you’ll follow it, I highly recommend you to run every make command with -j 2 or even -j 1 option. It will take more time, but this way you won’t get Out of swap error.
