Incosistent CSV Output
Hi Emlid Team,
I’ve noticed that sometimes when doing a “All Columns” CSV export that outputted fields are inconsistent, which is causing issues with our import scripts. For Example, “Control code” is not always there if the string hasn’t been closed as an example. Another example is “Tilt angle” being the fact that is only on newer units.
I could get around this by doing a custom CSV export but then some of the fields in the “All Columns” CSV export are not available in the radio tick box list (“Correction type" does not appear as an option when using the custom csv function).
Is it possible for the development team to update the “All Columns” export so that every available column is exported and remains consistent.
Cheers Jason
I agree with Jason on this. It would be really helpful to have a full featured, static format csv output option.
Hi @jlove,
Welcome to our Community Forum!
For exporting the CSV files, you can try using the reset button at the bottom of the page. That should organize the columns back to default, and you’ll be able to select both the control code and tilt angle columns from there.
Hi @ralphb,
I will pass your request for a static format CSV output to our development team—thanks for bringing it up!
