How to get fix solution
Hi everyone
I have been learning a lot about my reach thnaks to all the helpfull information from the forum, thanks for that.
I’m trying to setup my two reach devices as a survey tool, using one as base and the other as a rover.
I have communication betwenn both of them using two 3dr radios
My first question is about how to get fixed solution, I have only been available to get single solution
Im using two metal plates under both GPS antennas and have the base in a camera tripod
My second question is about the base position. When I’m connected to the rover using the reach view app, I can see the base position and it’s 0 for latitude longitude and height, why is this happening, How can I get it to have the position of my base device?
this are the settings I’m using as my correction inputs
From you first picture, you have extremly poor signals at the base and rover.
0 at base because signals are to poor for it to calculate a position. It need to get over a certain amount to output a solution.
Not sure what your surroundings looks like, but antenna need clear skyview for at least 30degr and above.
Thanks for the tip, I will try to look for a place with better conditions for the test
