How to do post-processing
Hello everyone. I want to learn how to perform post-processing with RTKLIB.
In most of the times I do not get a fixed solution with emlid reach rs, so I consider it important to learn (from scratch) the process to use RTKLIB.
Someone can instruct me with detailed step-by-step guidance.
Thank you!!!
Hello Mario,
Here is the link to PPK guide.
Hi friend, can you help me post-process?
I attach the data to verify my post-processing results.
Thank you!!!base_201805012250_RTCM3.zip (272.9 KB)
solution_201805012250_LLH.zip (230.5 KB)
raw_201805012250_RINEX-3_03.zip (4.1 MB)
base_raw_201805012240_RINEX-3_03.zip (6.4 MB)
I attach the captures of the post-processing results made.
I do not know if they are correct.
Thanks for your help!!!
Conf1Conf3Conf2
Looks ok, but dont use Glonass and Beidou together at the same time.
Friend, could you help me? I made two configurations.
I guess they are not good!
Confg. 1
341
Confg. 2
B6B7
What I’m interested in are the four points that I keep the team in floating mode, in total there are six, two of them with fixed solution.
I would appreciate the help !!!
Can someone help me with this. Please. Thank you
@emlid
